Bolts?
Old Aug 4, 2010 | 07:38 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Bolts?
I got myself a new air dam but i don't know what type of bolts &/or nuts to be using to install it. What is the appropriate hardware that came stock for this?
Old Aug 4, 2010 | 10:24 PM
wakeboardr42393's Avatar
Car: 1987 BMW 325is
Engine: M20B25
Transmission: Getrag 260
Axle/Gears: 3.73 LSD
Re: Bolts?
im not sure the answer to your question id just get new nuts and bolts and washers however if your trying to make your car stock then that wont be acceptable i undrstand. but just a question- how much did you pay for the air dam?
Old Aug 5, 2010 | 11:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Bolts?
Should be the M8 or so "screws" with the 10mm head I believe. It's about 15mm long. They sell them in the "HELP" section in the auto parts stores. They thread into those metal clips. It uses machine screw threads, not sheet metal threads.
Someone should be able to get you a picture here eh...?
Old Aug 6, 2010 | 08:27 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Bolts?
Thanks alot! Mine doesn't have the metal clips... just the pre-drilled holes on the radiator bar. So would that be in the help section too?
yes i'm trying to go stock.
got it for 48$ shipped from moderndaymuscle.com
Old Aug 6, 2010 | 04:13 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Bolts?
A good hardware store, one with a well stocked fastener section will have the clips ,"speedy nuts" is what theyre called, and the factory style bolts. Ive purchased both the speedy nuts and the bolts several times at True Value. Auto parts stores rarely have a decent fastener selection.
Old Aug 7, 2010 | 06:04 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Bolts?
M8 Bolt with M10 Head?
Old Aug 7, 2010 | 06:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Bolts?
Maybe something from the following company:
http://www.clipsandfasteners.com/
JamesC
Old Aug 16, 2010 | 09:19 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: Bolts?
I may be spoiled. Parkrose True Value here in Portland has the best fastener selection I have ever seen in one location. They have just about any style of fastener you might need in almost any size combination you could dream of.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
