car wont go faster the 6mph!?!?
Old Aug 12, 2010 | 01:47 PM
rock861261's Avatar
I have a 91 camaro and was leaking coolant from the water neck so I took the plenuem off replaced the water neck and now the car runs like crap and wont go over 6mph any ideas
I have checked for vacuum leaks and all my sensors are running i checked them with tuner rt.
Old Aug 12, 2010 | 01:56 PM
rock861261's Avatar
Re: car wont go faster the 6mph!?!?
i forgot to mention in ran good before disassembly
Old Aug 12, 2010 | 04:27 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Is your throttle cable damaged? 6 MPH is like putting the car in drive and letting it roll...
Old Aug 12, 2010 | 07:30 PM
rock861261's Avatar
no i can rev it in neutral...
Old Aug 12, 2010 | 07:41 PM
Pairof91rss's Avatar
Car: 1991 B4C-1991 RS
Engine: L98 5.7 TPI-LB9 5.0 TB
did you fill the coolant back up? park on an incline, so the front of your car is higher. start the car and open radiator cap (on a cold engine...) and fill with 50/50 coolant mix. Once the radiator seems full, have someone push the pedal dow, and the engine will "suck up" more of the coolant, allowing you to top it off. This should get rid of any air bubbles. Then maybe disconnect negative cable for a minute or two. Then take it out and drive normally for a bit, see if all that helps. Good luck
Old Aug 12, 2010 | 07:47 PM
rock861261's Avatar
yes i filled the coolant back up and the coolant sensor is reading fine as well
Old Aug 12, 2010 | 08:09 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Sounds like a transmission issue to me?
Old Aug 12, 2010 | 10:11 PM
rock861261's Avatar
no rebuilt tranny...
like i said it ran perfect before and it only sat one day
runs and feels like the tps is unplugged however its not and i get good readings on tuner rt
Old Aug 16, 2010 | 09:34 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The Troopers Are Going To Be Disappointed They Can’t Collect Speed Tax From You
Put the car in gear.
Try to achieve 3000 RPM for a few seconds.
What happens?
Can you acheive the RPM?
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Old Aug 16, 2010 | 11:04 AM
rock861261's Avatar
Re: The Troopers Are Going To Be Disappointed They Can’t Collect Speed Tax From You
hey guys i got it apparently when i pulled my pleneum off i hit my disb and retarded the timing 25 degrees
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
