bbc oil pan question
Old Aug 12, 2010 | 03:38 PM
gtanut's Avatar
does anyone know what the chances of a std vloume pump sucking a stock 5 qt pan dry thanks for the help
Old Aug 12, 2010 | 05:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: bbc oil pan question
About zero.
Old Aug 12, 2010 | 05:22 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
It could happen if you're running a sustained 5000 rpm, like putting a car pan in a boat. But just running down the 1/4 mile dragstrip, no worries.
Old Aug 12, 2010 | 05:45 PM
NAASBC355's Avatar
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
I've never seen a Chevy do it under street conditions or drag racing.
~Couch
Old Aug 12, 2010 | 06:46 PM
gtanut's Avatar
cruseing down the street if i bring it up to about 4500 for more than a second or two oil pressure goes from 50 to about 30 and stays there until i let off of it thanks guys
Old Aug 12, 2010 | 07:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You would have to stay above 7000 for a while to do it. I use a deep sump pan but only have 5-6 quarts in it plus a 3 quart accumulator as a back up. I spin my engine to 7400 and in a 9 second pass down the track, oil pressure stays a constant 70 psi. I only use a standard volume pump but use the high pressure spring.
It really depends on how much oil control you have in the engine. Get the oil back into the pan as fast as possible. Because I use a deep sump pan with a lower capacity in it, I don't use or need a windage tray. I also don't use lifter valley screens and my lifter valley is painted. I want the oil to drain back as fast as possible.
It's only when I quickly slow down after the finish line that I may see pressure drop. Even with the trap in the pan, the oil that's left in the pan moves forward away from the pickup tube. That's where the accumulator comes in. The way I have it set up, if my pressure drops below 15 PSI, the accumulator pushes oil back into the galleries until the pump can start pushing oil again. My low oil warning light is on a 25 PSI switch and it never comes on during a pass.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
