is my timing right?(with pics)
Old Aug 16, 2010 | 02:01 PM
Heavy_Chevy's Avatar
i have been going through my engine and i know i have lack of compression on all cylinders. i read that it could be because the cam is off a tooth or more. i have attached pictures is this right? also am i right to say that the small notch is the timing notch on the crankshaft? and the arrow the cam mark?
1989 camaro the engine is a 2.8 V6 FI with automatic trans
Attached Thumbnails is my timing right?(with pics)-dscn2658.jpg   is my timing right?(with pics)-dscn2665.jpg   is my timing right?(with pics)-dscn2666.jpg
Old Aug 16, 2010 | 09:56 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: is my timing right?(with pics)
The timing looks good bro. Whats the issue? If she doesnt start up and begins to backfire from the intake, then you may of had lined up the marks on the exaust stroke. No worries though. All you have to do is loosen up the dizzy, pull it up and rotate the rotor 180* and drop her back in. Make sure to pull out the dizzy far enough because if you dont, the slot that is in the bottom of the dizzy shaft will turn the oil pump shaft and it will be very difficult to sit the dizzy back down onto the oil pump shaft. Then give her a shot.
Old Aug 17, 2010 | 01:38 AM
you can read all about my problem in the V6 forum... but basically i'm a chevy virgin and i got the car with the engine not totally assembled...the thread is called "why won't it run". i'm just having not much more than trouble from this ride.
1984HO
Mar 19, 2021 11:59 AM
BADNBLK
Nov 16, 2016 09:12 AM
project89
Sep 24, 2015 06:38 AM
Linson
Aug 21, 2015 02:12 PM
cstrobel65
Aug 15, 2015 10:19 AM
