Anyone tried these on GM?
Old Aug 20, 2010 | 09:45 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
http://www.latemodelrestoration.com/...m-Change-Tools I don't see why we couldn't use these on our gm heads? Wouldn't have to take lower intake off our cars.
Old Aug 20, 2010 | 05:55 PM
EvilCartman's Avatar
Car: '82 Z28
Re: Anyone tried these on GM?
I don't see why you couldn't make these yourself to try out. All thread, wing nut, heat shrink and some neodymium magnets. Sure suck if one let loose.
Old Aug 21, 2010 | 02:13 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
For the time it takes to rig these things to each lifter you could have the
intake off the motor already! Air tools make disassembly real quick!
Old Aug 21, 2010 | 02:18 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Id be a little leery of using those. If one of the lifters falls, youll be pulling the pan as well to get it back.
Twin_Turbo's Avatar
The spider plate pushing down the dog bones and lifters is gonna be a problem
Old Aug 21, 2010 | 07:41 AM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
that goes to show how people are getting lazy to do things the right way, if your changing a non rollor cam you should chage the lifters aswell, just freakin to lazy to pull an easy intake........you really want to use ford tools on a chevy?............
Old Aug 21, 2010 | 03:07 PM
ninetyone's Avatar
Axle/Gears: 3:42
Well, then I will give you my address and you can bring your compressor and air tools over then.
Old Aug 21, 2010 | 03:10 PM
ninetyone's Avatar
Axle/Gears: 3:42
Basically, I just want to put in a computer compatible cam for now. I do most of my driving around town and like the low end torque that our car's have.LOL I don't like getting left behind in traffic,but if I stomp it WOT that is a whole other story, as most of us know.
Old Aug 21, 2010 | 03:12 PM
ninetyone's Avatar
Axle/Gears: 3:42
Why, I have worked on Ford 5.0 motors before and if i can recall they have a spider plate and dogbones holding down the roller lifters too.
Old Aug 22, 2010 | 09:17 AM
Car: '82 Z28
Why the hell do you need to use air tools? Are you REALLY that lazy you can't turn a simple wrench?
Old Aug 22, 2010 | 09:31 AM
ninetyone's Avatar
Axle/Gears: 3:42
No, not lazy. If I can save a few hours work. Why not. I would pay $50 for that
Old Aug 22, 2010 | 12:29 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
In addition to the spide and dog bones, on the LTs you'd also have the stud shaft issue. I don't see a work-around to those.
Jake
Old Aug 22, 2010 | 01:01 PM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
seems like the same type of "MOD" as the fuel hatch guys...yano next time i change my trans i think im going to go through the trans tunnel....it just seems easier!
if you dont want to take the "couple hours" to do the job rite...then dont do the job
