do i need a plug?
Old Aug 23, 2010 | 06:52 PM
sethorama's Avatar
do i need a plug?
ok i filled my rad up with fluid and i started leaking fluid out of a hole between 1 and 3 spark plug hole
its a late 70 model 350
the hole is rite by the header somewhat
i think its where i plug my therm meter up to
but what do i put in there to keep it from coming out?
i was told it was a freeze plug but idk
thanks
Old Aug 23, 2010 | 06:59 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: do i need a plug?
It should just be a pipe plug. Its either 3/8" or 1/2" NPT.
What did you take out? If you took something out, thats why its leaking.
Old Aug 23, 2010 | 07:54 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
It will be 3/8 NPT, like stated above. Really common, easy to find size. Just put a plug in it, be sure to use thread sealer or teflon tape.
Old Aug 23, 2010 | 08:36 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
I'm not too sure about plugging it up because that's where my temp sender is installed.
I have a hole like that on both heads.
The other is plugged but should hold my temperature switch. I could not get the plug out...snapped a brand new alan wrench socket trying...much to the displeasure of my friend who lent me the tool to remove it...lol.
However, Your setup may be different and have the sender somewhere else??
Though you say that's where you hook up your therm meter??
So what did you remove in order to hook up your meter in the first place??
Old Aug 23, 2010 | 09:24 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Until mid '80's most heads were 1/2"NPT
Old Aug 23, 2010 | 11:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Your sender for the coolant guage is supposed to be in that hole.
Old Aug 24, 2010 | 09:11 AM
sethorama's Avatar
no i didnt take it out.
it was already out
was filling up with coolant to fire up the engine than see it
Old Aug 24, 2010 | 09:12 AM
sethorama's Avatar
is there a specific kind of plug i need to use it for my coolant gauge
Old Aug 24, 2010 | 09:26 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'd need a coolant temperature sender, not a plug. If the hole in the head is bigger than the sender, use a pipe bushing.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
