Can you figure compression ratio before assembly?
Old Aug 23, 2010 | 11:55 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
getting a custom chip done for my 90 iroc
putting a new engine together but havent begun and dont be able to for a little while longer
is there any way to figure out the ratio but the parts (ie. heads, bore) ect?
Old Aug 24, 2010 | 12:28 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can you figure compression ratio before assembly?
You can calculate the compression ratio from the nominal specs of all the components. The exact value may vary from this by a small amount depending on the exact final configuration.
Old Aug 24, 2010 | 12:35 AM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
what info do i need and how do i calculate it ?
Old Aug 24, 2010 | 12:59 AM
Guest
Guest
Posts: n/a
If you find an online calculator it'll tell you what you need to know.
Bore
Stroke
Depth of piston from deck of block at TDC (there are ways around actually measuring but of course room for error by not measuring)
CC of dish or dome on piston
Gasket cc (can figure from bore size and gasket thickness)
Combustion chamber cc
Old Aug 24, 2010 | 02:51 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Download and install this calculator
http://cochise.uia.net/pkelley2/dcrvb6.zip
Does static compression ratio calc and if you have cam specs does DCR as well .Just put info in the boxes
Old Aug 24, 2010 | 02:44 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
what is DCR?
Old Aug 24, 2010 | 02:52 PM
Guest
Guest
Posts: n/a
Dynamic compression ratio. Most people when they talk about compression ratio, they're referring to static.
Old Aug 30, 2010 | 02:05 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
how can i figure out the valve relief (in positive cc) ? im unable to get ahold of the shop i bought the engine from right now,is there a general kinda number? they dont look to radical theyre flat tops just have the valve reliefs .
Old Aug 30, 2010 | 02:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Have you got a part number for the piston?
Old Aug 30, 2010 | 02:36 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
2 valve relief pistons (one intake and one exhaust) are in the 6 cc range.
Jake
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
