Valve Adjustment for a 350 L98
Old Aug 24, 2010 | 10:00 PM
CooterB's Avatar
im rebuilding a 87 350 l98 just wondering if the valve adjustment is the same as any 350
Old Aug 24, 2010 | 10:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Valve Adjustment for a 350 L98
As any 350 with a hydraulic cam, yes.
Old Aug 24, 2010 | 10:06 PM
CooterB's Avatar
is there a special procedure with a hydraulic cam is the 3/4 turn after the zero lash sufficent
Old Aug 24, 2010 | 10:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That is the special procedure. 3/4 turn is fine. GM says to use as much as 1 1/2 turn with a new cam and lifters.
NBrehm
Aug 25, 2015 11:49 PM
crazynights
Aug 21, 2015 06:53 AM
Out-Cast
Aug 17, 2015 10:57 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
