broke crossmember bolts
Old Aug 25, 2010 | 06:09 PM
87firebird305V8's Avatar
Car: 87 firebird
Engine: carbed 305
ok i broke every crossmember bolt, and i be tried to drill it out with little sucess/ ive brike like 5 drill bits. does anyone have any tips or hints to get them out. i was also thinking about welding it onto the front subframe. would that work
Old Aug 25, 2010 | 10:07 PM
alexisgreene's Avatar
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: broke crossmember bolts
A trick I learned to get broken bolts out is to take a chisel, scraper, or anything that can cut a straight groove into the broken bolt, then use a flat head and turn it out by hand. Now if the bolt broke far enough into hole I would take my smallest flathead and a hammer and pound in into bolt a few times and then begin turning. I have removed countless broken oil pan bolts like this.
Old Aug 26, 2010 | 10:34 AM
Car: 87 firebird
Engine: carbed 305
ok ill try that
Old Aug 26, 2010 | 10:51 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
get better drill bits. I had my brother change my friends trans mount at the shop and 2 of the 4 bolts snapped flush.
His bits weren't that sharp so it took about an hour to drill them out.
Get some Tungsten Carbide bits.
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
