Headers for my 383 TPI
Old Aug 30, 2010 | 04:16 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am currently building a 383 TPI for my car and was unsure about what size headers to go with. I have a set of Hooker 2460's (1 5/8") on the car now and I just purchased a set of Dyno Don's 1 3/4" headers. The motor has a 224/230 @ .050 cam in it, AFR 195cc cylinder heads, and a complete TPIS Intake set-up on the car. Will these 1 3/4" headers be too much for the motor causing a power loss down low, or will I be fine and only gain power?
Old Aug 30, 2010 | 08:38 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Re: Headers for my 383 TPI
im running the same headers as you and ive been recommended to change them to some dyno dons or SLP headers (1 3/4). i guess it just depends wats ur set up..i am also ready to do a 383 setup on mine.oh and i got recommended also to go 3.5 in exhaust
Old Sep 6, 2010 | 04:19 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Does anybody think my set up will benefit from the 1 3/4" headers? I heard that the AFR's need dyno dons headers to clear the exhaust ports.
Old Sep 12, 2010 | 09:14 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Any ideas?
Old Sep 12, 2010 | 09:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yes, run the 1 3/4's. 1 5/8 wont cover the entire exhaust port on AFR heads but a 383 really can benefit from a good 1 3/4 tube
Old Sep 12, 2010 | 10:42 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Dittos. Run the 1 3/4 inch headers. You do not want to cover the exhaust ports and Dyno Dons as far as I know are the only ones that do not on AFR heads.
Old Sep 13, 2010 | 06:23 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Will I have any power loss down low due to the larger primaries?
Old Sep 13, 2010 | 06:31 PM
AmorgetRS's Avatar
You have a 383 TPI motor... why are you worried about power loss down low? You should have plenty.
Old Sep 13, 2010 | 06:57 PM
Car: 1989 GTA
Engine: 369 TPI
"Will I have any power loss down low due to the larger primaries?"
As the above poster stated, "no". Go with the 1 3/4" primary tubes.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
