aftermarket air cleaner
Old Sep 5, 2010 | 02:28 PM
visago's Avatar
I bought an aftermarket are cleaner and went to install...what are the small electrical wire running into the bottom of the factory air cleaner and what should i do with it? The aftermarket piece doesnt have a spot for it.
Old Sep 5, 2010 | 02:36 PM
nickhil2003's Avatar
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
Re: aftermarket air cleaner
i cant recall off the top of my head what it is, but the car does not need it to run, but if left unhooked it will send a trouble code, you can take it off the original air cleaner base and hook it up and leave it in the engine bay somewhere, or make a hole in the new air cleaner base and mount it there.
Old Sep 5, 2010 | 03:09 PM
visago's Avatar
yea, i found somewhere that its a temp sensor and it can be relocated to the firewall, anyone know about the vacuum line thing , mine says AC on it, about an inch long and a half inch wide
Old Sep 5, 2010 | 03:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's for the thermac valve, you'll plug it if you remove the air cleaner.
Old Sep 5, 2010 | 03:48 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Its the intake air temperature sensor, or the IAT. Remove from the stock housing and plug back in to the harness. Relocate it somewhere that it doesn't get to much heat and gives a true representation of the actual temperature of the air going in. Plug off the vacuum tap on the TBI or carb that the line ran to.
83 Crossfire TA
Jan 3, 2016 01:26 PM
86IROC112
Sep 7, 2015 01:37 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
BurlyChev
Aug 22, 2015 01:52 PM
92purpz28
Aug 11, 2015 02:30 PM
