can someone please tell me where this vacuum line goes?? (pic)
Old Sep 5, 2010 | 02:30 PM
Black Flies's Avatar
Car: 1992 Z28
having a hard time with this one.. this rubber hose has good suction on it when engine is running, but i see nowhere for it to go
please help!!!
im lost
Attached Thumbnails can someone please tell me where this vacuum line goes?? (pic)-photo0198.jpg   can someone please tell me where this vacuum line goes?? (pic)-photo0197.jpg
Old Sep 5, 2010 | 02:33 PM
Twin_Turbo's Avatar
Re: can someone please tell me where this vacuum line goes?? (pic)
I think it's for the cruise control servo if I remember correctly, the T piece is a vac delay valve.
Old Sep 5, 2010 | 02:54 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
please help!!!
im lost
make sure its not the egr valve hose if its not that could be the cruise servo
Old Sep 5, 2010 | 03:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, should run all the way around to the cruise module behind and below the driver headlights. Usually runs around the back of the engine by the firewall, over the brake booster, and down the edge of the engine compartment to the front, you might find a connector there somewhere
Old Sep 5, 2010 | 07:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There are several things in front driver side that get vacuum - cruise being one. There's also the evap canister, and the vacuum ball under the evap canister. That T is actually a one way valve, so that the vacuum can't 'leak' out of the vacuum ball back into the intake - that way the vacuum ball can 'store' vacuum for the heater/A/C controls so that they still work in low vacuum conditions.
Old Sep 5, 2010 | 07:26 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Well, in my car, a 305 TBI, the vacuum line comes around the windshield washer tank and then splits in a T fitting, with the bottom line going to the vacuum ball, and the other line continuing on to the cruise module. The evap canister gets vacuum from the TBI.
Old Sep 5, 2010 | 07:47 PM
Car: 1992 Z28
oh.. great.. all good info
i however do not see another open ended line or connection.. i must have something hooked up wrong... but then id think there would be another open ended connection somewhere anyway.
Old Sep 6, 2010 | 02:48 PM
Twin_Turbo's Avatar
That line runs to both the cruise servo and the vac reservoir. the servo is T-ed off the line up front. There must be an open line that runs near the wiper motor since that end is open on yours. The other side is to manifold & interior hvac controls.
Old Sep 6, 2010 | 07:46 PM
Car: 1992 Z28
yes, i see what you are saying...
but all of that is hooked up already to another line.
is there a good online diagram of all of this stuff besides the one on the underside of the hood of the car its self?
crap.. anyone here live close to me so i can look at ur car?
Old Sep 6, 2010 | 08:14 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If by all that is hooked up you mean the cruise module and the vacuum ball, where do the lines from those places go to? Maybe to the wrong place?
Old Sep 6, 2010 | 08:24 PM
Car: 1992 Z28
may be..
but then where is the one line that is not hooked up?
lol
Old Sep 6, 2010 | 09:48 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I don't know, but hey you didn't answer my question. Aw man...
And do your HVAC controls that switch between defrost and heat, or vents work right?
Old Sep 6, 2010 | 09:50 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
On my 86 the vac line comes off the back of the plenum by the distributor on the right side and wraps around to the wiper motor area where it goes into that oneway thing then t's off and a hard plastic line goes back to the heater area. The original rubber line goes on around to the left front by the battery where it t's again. one goes down to the vac ball and the other too the cruise.
I could probably get pics if it will help.
Old Sep 6, 2010 | 10:01 PM
Car: 1992 Z28
sometimes...
when it doesnt, i only get vent air no matter what setting its on
Old Sep 6, 2010 | 10:17 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
1piece@atime's is set up just like mine and probably how yours should be. The rubber vacuum line coming back from the cruise module and vacuum ball should be connected to that piece in your hand. Can you do that from where they go now? Where is it that they go now?
Right now that's the leak that is preventing the HVAC controls from working right also.
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
cstrobel65
Aug 15, 2015 10:19 AM
apie2546
Aug 10, 2015 05:43 PM
