can this bent distributor be repaired?
Old Sep 6, 2010 | 04:03 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
could this be fixed with a mallet or something at home, need to go to a machine shop, or is this thing scrap? i dont see any cracks in it, and the part that hasnt been bent seems perfectly straight.
Old Sep 6, 2010 | 04:09 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: can this bent distributor be repaired?
Yes you could repair it, but you could also find a good used one at a junk yard for cheap, and that would be the better route to go. Just get it and swap parts from the bent one to the used one.
Old Sep 6, 2010 | 04:15 PM
1meanGTA's Avatar
its an msd distributor, i can put the guts from it into a stock distributor?
Old Sep 6, 2010 | 05:03 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Don't see why you couldn't just hammer it flat again.
You sure it's a msd distributor, thought they were all billet aluminum cause that one looks stock.
Old Sep 6, 2010 | 05:21 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
looks like a stocker with newer pickup installed.. but if it were me I would grab the big channel locks and bend it flat. but as long as the cap sits strait your fine. and from the picture both mounting points look untouched so it would be good
Old Sep 6, 2010 | 06:33 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Looks like a Cardone one from kragens/OReileys. Bend don't hammer. You want to use a vise or something that will help you keep the piece of metal straight. If you can get it so the cap sits on straight it should work OK. You may want to check after it's installed and been run to make sure the rotor is not hitting the cap or contacts unevenly
Old Sep 6, 2010 | 07:28 PM
kd5icr's Avatar
Axle/Gears: Stock
I am sorry but that cant be a MSD distributor, I see a MSD hot box but the distributor in your hand looks bone stock. And even if it were an MSD it will still be the same size as a stock one, because it has to fit in the same place. The thing about bending it back onto shape is that it may not seal right and you could get water up into it. Thats a chance you will have to take. Also I dont know if it is the way you are holding it but even the pick up coil looks off like it to is bent in that photo.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
ironbmt
Sep 27, 2015 06:00 AM
Damon
Sep 26, 2015 04:29 PM
