Smoke machine to find vacuum leaks
Old Sep 9, 2010 | 03:10 AM
joshwilson3's Avatar
Old Sep 9, 2010 | 05:58 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Smoke machine to find vacuum leaks
I've used a ciggarette before, kinda hard to spot it tho lol I don't see why you'd wanna build a smoke machine, you could just spray some ether around the suspected areas and listen for a change in idle, if you want a cheap route for the smoke thing id find some clove cigs and use those lol just light it and put it up to the booster line, the smokes thicker IIRC I'm a fan of the ether tho, cleans the motor off in the process lol
Old Sep 9, 2010 | 06:09 AM
Old Sep 9, 2010 | 06:18 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
This is true, but there are problematic spots on our car that where I start normally, I'm not sure how to power a plug but I'm thinking you should use a 12V battery, I know they heat when a current is run thru them like a fillament on a light bulb
Old Sep 9, 2010 | 06:27 AM
Old Sep 9, 2010 | 07:37 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Id say check your tps and iac, reset them along with the min air, also look into greasing the tb and the pedal, my tbi was doing something similar but once I kicked the gas it would loosen up, and go down. I bet once you reset the tps iac and min air it should be good, don't forget to clean the iac while you're at it
Old Sep 9, 2010 | 07:53 AM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
