Short at the starter
Old Sep 9, 2010 | 01:20 PM
Allamericantc's Avatar
Car: 87 TA
Engine: 355
Guys,
I just put in my brand new, rebuilt 355 carbed. I have all wiring out from the TPI that used to be in there. As I was setting the timing yesterday, I was planning on just hitting the key a couple times to get the motor in the correct position to set the dizzy. Upon attempting to start the car, I got a click sound, that sounded like it was coming from the starter, at which point all power went out. I tried again and nothing happened. No lights or anything. About 5 minutes later, the car had power again. I then went to start it and it clicked and lost all power again. Any clue on what the deal is?
Thanks!
Old Sep 9, 2010 | 05:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Short at the starter
You've got something wired wrong. Starter should get all the fusible links and the pos batt cable on the large terminal, and ONLY the purple wire on the smaller terminal.
mcbitchman
Sep 30, 2015 01:00 PM
mcbitchman
Sep 29, 2015 12:32 AM
J.C. Denton
Sep 21, 2015 04:23 PM
sahlomonic
Sep 20, 2015 07:15 PM
Formula_88AE
Sep 3, 2015 01:47 PM
