Nylon gear teeth?
Nylon gear teeth?
Does any one know if all the 305's and 350's put in third gens have nylon teeth on the timing gears or is it just certain years? I'm hoping GM might have smartened up in the later years and put in completely steel gears.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Nylon gear teeth?
Many factory timing chain sets have nylon teeth gears. It makes them very quiet.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
all the original '86 and earlier thirdgen engines i have
had apart did have the nylon teeth as did the '84 vette
350 i put in my car-however an original 350 i took
from an '83 cop car had iron gear,so possibly certain
H/D fleet apps had the iron.
i have not checked '87 up roller cam 3rd gen engines,
but all other original roller cam engines i have had
apart all had iron gears-the roller engines use a slighty
different design gear in order to accomodate the
thrust plate
thrust plate
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
My early 86 iron head 350 Vette engine (flat tappet L98 model) had all steel gears.
4-bolt main, one piece rear main seal block, but no roller cam mounting provision. Sort of a hybrid.
Jake
Jake
I was thinkin maybe the 87' and newer L98's would have solid gears since chevy used em' in the vette's. Senior Member
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
there were installed in the early 80's
I believe they installed steel gears again 85....
I have yet to see them.. 86 - current
Car: 1992 RS
Engine: Carbed 350
I never heard of such a thing in a SBC - sounds like Jap Junk to me - I'd only want steel.
Car: '82 z28
Engine: L83 5.7
chevy started using the nylon teeth somewhere around
1965-they actually wear pretty decent,problem is as
the plastic teeth age they shrink a little and crack loose
from the aluminum hub plate.
The original set on my '74 nova lasted exactly 140,000
mi...
(this was back in '86)
mi...
(this was back in '86) Member
Car: 84 Trans Am
I was coming home from the beach when I was in high school and out 84 T/A just quit with no indication of a problem. $250 tow bill. Sure enough the crank gear lost all its teeth.
Car: 1982 Pontiac Firebird Trans Am
Engine: 350ci, 882 heads, mild cam
Transmission: Turbohydramatic 350
Axle/Gears: Factory GM 10 bolt
My '82 T/A had a nylon cam gear, as did the '75 SBC in my wife's Camaro, both were replaced with true double roller timing chains. Don't ask me if the new chains are quiet though, can't hear 'em over the exhaust.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
