need help on identifying engine vortech or pre 86?
Old Sep 13, 2010 | 09:43 PM
srosscamaro@aol's Avatar
Car: 85 trans am
Engine: 5.7 goodwrench edelbrock everything
Transmission: t-5 stage 2 clutch
Axle/Gears: 3.27 posi
i have a gm goodwrench 305 that has a roller cam set up in it from the factory and old style heads not ceter bolts casting number10243878 what kind of enginge is it vortech or what it has a one peice rear main as well head castings are 14014416 ive never seen one like this its like it has a vortech bottem end and pre 86 top end ps this engine is in stock form from gm with the made in mexico on the back
Old Sep 14, 2010 | 03:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: need help on identifying engine vortech or pre 86?
Almost all 1986 and newer motors are "roller" motors and are one piece rear main seal types. THis particular casting number means the engine was used in 1996 chevy trucks and is a "roller" motor but is not a vortec.
Old Sep 14, 2010 | 11:44 PM
Car: 85 trans am
turns out it is a gm crate motr but its a vortech bottem end with 80-86 model heads no longer made by gm only made with the center bolt heads now
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
