vin says 305 i was told 350 how can i tell
Car: 91 RS, 93 k1500
Transmission: T5, NV3500
Axle/Gears: stock
i recently traded my 87 camaro for what i was told was a 87 iroc L98. i just checked the vin the other night and it turns out it is a 86 305 car. i know the engine was out at one point. is there anyway i can tell if its a 305 or 350 with out tearing the engine apart to check the bore diameter?
anybody who can help me please let me know.
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
Re: vin says 305 i was told 350 how can i tell
get the numbers off the back of the block, just look behind the heads, post them up or search them.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Facing straight up, down behind the head.
i just bought an 87 for a parts car it has a 350 in it, the engine is not original to the car; i decoded the vin. i cannot see any casting number on the back only the 57lg stamp. i am going to stroke it and dont know if i have a 1 or 2 piece rms, i do know that this is a newer engine because the top pans have 4 inline bolts keeping them on. anyone have any knowledge about this?????
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Car: 82 Z28
Transmission: T400
Engine: 4++,350 & 305 CIs
I have seen them also.. some very early truck roller cam motors had goofy machine work done to them from the factory..
I have seen a 2piece rear crank and funky seal adapter on a original factory truck motor with 57l cast in it. The roller stuff cast in the top but not machined.
It looked like one of those aftermarket adapter thats out now 2 put a older crank in a newer motor.. but I know it was org and I was 1st to take trans out..
Family ownd truck bought new.
I have also seen the normal ole 2piece seal motor with that 57 in it.
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Now I'm not sure if you meant later blocks but you didn't specify.
I can provide a pic if needed. I took many when I was dismantling first time. I was looking for a lot of info back then (3 yrs ago almost). My story is on here so to speak. And another site.
Car: 82 Z28
Transmission: T400
Thinking about it now , I have no experience with the 81 -85 blocks where the dipstick was swapped to pass side so maybe the change was there and not with the 1 pce RMS blocks as I thought ?
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
That's possible. I have no experience with any other SBC except my own...
And boy has this been an experience.
I've learned a heck of a lot about the sbc just from reading this site.
I spend a good while reading this forum just for knowledge about our cars, probably a couple hours a night 3-4 nights a week sometimes more.
It threw me when you said about the stamp...I was thinking I had some special engine...lol. Oh well.
