Fuel smell with 305 TPI; lack of power
Old Sep 18, 2010 | 04:21 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I took the car for a longer drive than normal today (~150miles) and on the way home, I noticed a raw gas smell while driving. It didn't seem to matter what speed or gear as to the potency of the gas smell.
I also noticed a noticeable drop in power and mileage, so I'm convinced that its leaking.
I've checked the rails on the motor as well as I can since the motor is HOT, and I don't see anything dripping.
Are there any common failure points to check? Any idea where the smell is coming into the cabin?
Old Sep 18, 2010 | 04:26 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Re: Fuel smell with 305 TPI; lack of power
Check your fuel pressure? My stock FPR went bad and it was burning my eyes in idle. It wasn't leaking externally, but 54lbs isn't stock. So i bought a Holley and everything is good.
Old Sep 18, 2010 | 08:38 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
How do I check the fuel pressure?
Old Sep 19, 2010 | 10:20 AM
Car: 1994 Trans Am
With a fuel pressure gauge hooked up to the schrader valve on the fuel rail with a vacuum line disconnected from the Fuel pressure regulator. Turn on the car and see where its at.
Old Oct 8, 2010 | 01:34 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I haven't had an opportunity to check the F/P yet, but I did have another question as the gas smell seems to be occurring after the car has been running a while and is completely up to temp...
Would the gas cap have anything to do with the tank's ability to vent or anything? I ask because EVERY time I open the cap to put gas in, it lets a large "PSSSSSHHHH" out, moreso than any other car I've had... just seems a little wierd; its always like that, no matter the outside temp or how low/full the tank is prior to opening.
I've got an aftermarket locking gas cap and maybe its the wrong one?!?!
Old Oct 11, 2010 | 07:28 PM
Tafsky86's Avatar
I would suggest getting a GM cap from a Chevy dealer. I also get that same noise when I take my gas cap off. I do not have any issues with my car whatsoever that I am aware of. I believe that is normal... this coming from the fact I have owned 6f-bodies all with V8's.
Old Oct 11, 2010 | 07:33 PM
Car: 1994 Trans Am
I get that whoosh sound and it's normal on all the fbodies Ive owned.
Look underneath the plenum and runners for wetness. I had a couple fuel rail o-rings break and fuel was spraying out into that valley under the intake.
jaridjohn
Jul 8, 2024 03:49 PM
Brcharrelson
Aug 26, 2015 07:47 PM
InfinityShade
Aug 22, 2015 08:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
