shakes when I break...
Old Sep 22, 2010 | 03:19 PM
mjc928's Avatar
Not sure if this is in the right spot but here it goes... So the other day I was driving home and approached a light. As I hit the break to slow down, my car started to shake. Any ideas on what could be wrong?
Old Sep 22, 2010 | 03:23 PM
krazefbird's Avatar
Car: 84 Firebird
Engine: currently 1968 307
Axle/Gears: 3.23 lim slip
Re: shakes when I break...
Brake rotors are warped. Have had this problem a few times. Is the brake pedal real stiff?
Old Sep 23, 2010 | 08:01 PM
mjc928's Avatar
no the brake pedal is fine.
Old Sep 23, 2010 | 10:18 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Did it feel like the front wheels were about to come off? It is probably the front rubber brake hose's. Change them both. This is a really common problem.
Old Sep 23, 2010 | 10:50 PM
slowpoke's Avatar
Car: 1987 Z28
Axle/Gears: 273 Limited Slip
I agree with Doom86. Lines only about $10.00 Mine was doing the same thing. Put new rotors and pads. The brake hoses were actually resticting fluid. I could apply pressure but it would not release when I let off the brake. I changed them and all good now.
Old Sep 23, 2010 | 11:35 PM
formula27's Avatar
warped rotors/drums whichever you have, when out of round the pads/shoes contact them here and there rather than constant. Have them turned at your local auto parts store. Also if using your brakes constantly in traffic, causing your rotors/drums to become real hot-refrain from using your e-brake when parking shortly after getting the brakes this hot (steel becomes softer and pulling real hard on that e-brake handle can warp them out again)
Old Sep 24, 2010 | 04:06 PM
krazefbird's Avatar
Car: 84 Firebird
I don't remember the last time or if I have changed my brake lines at all and I've had the bird since 99. The reason I asked about the pedal being stiff is when my car was doing that it was like the pads got siezed on the rotor or stuck or something. I had to do a quick tap on the pedal to loosen the brakes up. Anyway, turning the rotors and putting new pads on will cure the problem more than likely, if not then it's obviously something else. But start with the rotors and pads.
Old Sep 24, 2010 | 04:48 PM
Doom86's Avatar
It's not the brake line its the brake hose that connects the line to the caliper they internally collapse. I've had this happen to both of my fbodies.
Old Sep 25, 2010 | 09:48 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
if you have the rotors turned make sure thay measure them before to see if they are thick enough to be turned and after they are turned to double check.
Old Sep 27, 2010 | 03:34 PM
krazefbird's Avatar
Car: 84 Firebird
Alright well can't hurt to spend the extra $ and replace the lines, although after shaking the hell out of my front end, turned rotors and new pads worked for me. And yeah, I know the dif between a line and a hose.
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
xxx3man`
Sep 23, 2015 10:37 PM
88rscamar0
Sep 23, 2015 09:08 PM
Amillionoh7
Sep 5, 2015 11:44 PM
