Harmonic balancer / Damper replacement what else if anything should be replaced?
Old Sep 24, 2010 | 11:08 AM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
When I had my engine built the builder reused my old Harmonic Balancer/ Damper. He used a Harmonic Balancer repair sleeve( see below). I want to pull the balancer and install a new one since the one he used is 20 years old. What else do I need to replace if anything? The engine has been run for less than 5 hours since it was built.
http://www.summitracing.com/parts/FEL-16202/
I will be using this balancer:
http://www.summitracing.com/parts/SUM-161350/
Old Sep 24, 2010 | 11:26 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Harmonic balancer / Damper replacement what else if anything should be replaced?
Probably want a new front main seal to go with it after you've used a bushing.
Old Sep 25, 2010 | 11:32 AM
THETANK's Avatar
Car: 91 rs
Is this the correct part that I need?
http://www.summitracing.com/parts/MRG-18/?rtype=10
Old Sep 25, 2010 | 11:35 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That should work.
MoJoe
Sep 15, 2015 12:50 AM
theshackle
Aug 22, 2015 06:52 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
