Oil out the dipstick tube
Old Sep 25, 2010 | 09:48 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
My buddy just picked up a 305 tbi and it pukes oil out the top of the dipstick tube. Compression is 180-205. What else can we check?
Old Sep 25, 2010 | 09:57 PM
skinny z's Avatar
Re: Oil out the dipstick tube
Check the PCV system. Unless it's working properly, cylinder blowby will increase crankcase pressure to the point where oil will be forced out anyplace it can.
Nice compression pressure by the way. Bit of a spread but it's good to see 200 psi.
Old Sep 25, 2010 | 10:01 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
There's a new breather on the passenger side, and a new pcv valve on the driver's.
Old Sep 25, 2010 | 10:07 PM
skinny z's Avatar
Other than checking that the PCV is working correctly (despite the presence of the breather and the valve) my only other suggestion is a leak down test. That'll determine if that nice high compression you have is overwhelming the PCV and causing your problem.
gta892000
Aug 11, 2019 11:16 AM
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
BDR
Nov 7, 2015 03:05 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
