3.1 v6
Old Oct 5, 2010 | 12:25 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
3.1 v6
ok so my car is making a screaching noise i found out it is the smog pump . is there anyway that i can delete the smog pump off my motor
Old Oct 5, 2010 | 01:37 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 3.1 v6
Sounds like your smog pump has frozen causing the belt to rub over a smog pulley that does not turn. I assume the V6 cars still have the same sort of serp belt setup - if so the smog pump can be deleted out of the system by simply changing belt length and rerouting the serp belt - your answers are here: https://www.thirdgen.org/serpentine
Old Oct 5, 2010 | 02:00 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
Re: 3.1 v6
ok i will check it out .. the pullie is spinning bc i did take the belt off nd turn it by hand but its making funky noises when i turn it so i want to delete it
Old Oct 5, 2010 | 02:13 PM
1sckrs's Avatar
Car: 91 camaro rs
Engine: 3.1 v6 baby
Re: 3.1 v6
the only problem is my car is a 91 v6 nd the diagram given is set up different then the way my engine is , so i am a little confused
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
