1989 camaro rs and ZZ4 350?
Old Oct 5, 2010 | 01:05 PM
bartstalder's Avatar
Does this work? I want to put the GM performance ZZ4 350 in my 89 RS and don't know if this will work. Can some let me know please? I also want to throw a T56 on my car and need advice to get the right conversion kit and such. I am looking on Summits site and have seen some parts and such, but can someone give me advice?
Old Oct 5, 2010 | 01:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 1989 camaro rs and ZZ4 350?
ZZ4 is a 350, any 350 will install. There's a ton of T56 swap info in the tranny section.
Old Oct 5, 2010 | 03:44 PM
Ok, Thanks. I am rather new at the motor types and such. Do I need any special motor mounts or is it all set and ready to install on the old mount locations?
Old Oct 5, 2010 | 05:10 PM
Car: 1992 RS
Engine: Carbed 350
Should all bolt in - nothing special about a ZZ4 block, it just has nice heads and cam for power.
Old Oct 5, 2010 | 06:28 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
The thing you should ask yourself is if you plan to keep a TBI or go Carb. If you keep your TBI you will need to spend some time tuning in the combo as well as a bigger TBI unit, injectors, etc. It can get more technical to do so.
Old Oct 5, 2010 | 07:03 PM
I do plan to go Carb. I want to put a Holley on it, but I don't really know much there either. Which model and type should I use. I plan to use it as a weekender with power that can still be used in the street. I don't plan to pull to much out of it but want strong car for now. The inspection laws here are pretty strict so I don't have too much room to mess around but yet more than I feel. I was thinking a Holley 750 dp, would that work guys? Is it reliable?
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Rustyweb7
Aug 9, 2015 03:05 AM
antares57
Aug 6, 2015 07:47 AM
