Having many problems.
Old Oct 7, 2010 | 07:04 PM
michaelpeerman's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
I have a 1991 305 TBI. It idles great and revs up normally when in park. When you go to drive it and start giving it gas it will build speed for a second then lose all power and after it does this and you put it in park it wont rev past 2000 rpm until you turn the car off then it will idle and rev right again till u start driving it. I had a buddy watch the throttle body and injectors while i reved it in park after one of these episodes. When it hit 2000 rpm it was still spraying fuel but not igniting it cuz i lost all power. Can you please help me figure out the problem.
Old Oct 7, 2010 | 07:48 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: Having many problems.
See if your check engine soon light is on. If so, check it for codes via code reader at auto parts store for free or use paperclip method first to see code # and if it will give you any clues as to why this is happening.
Old Oct 7, 2010 | 08:08 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Thats a problem cuz my check engine light never comes on even when i cross aldl ports a and b
Old Oct 7, 2010 | 08:27 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Fuel filter maybe? Did you check all ignition connections and related like cap, rotor, coil, etc?
Old Oct 7, 2010 | 08:46 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Ok I got the check engine light to work and the code it threw were all caused by me except one a code 53 (system over voltage)
Old Oct 7, 2010 | 08:47 PM
Car: 1991 Camaro RS
Engine: 305 TBI
I have replaced the fuel filter. As faras the other ignition componets go I figured they were fine seeing how when it doesnt act up it can rev to 6500 prm without missing a beat
MM2Robinson
Oct 1, 2017 09:16 AM
tyeo098
Nov 30, 2015 06:27 PM
bjpotter
Oct 4, 2015 07:48 PM
Camaroguy2
Sep 22, 2015 08:22 AM
Ranbo108
Sep 9, 2015 12:20 PM
