rear main seal leaking?
Old Oct 10, 2010 | 10:49 AM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, my 91 TA has an oil leak somewhere at the back of the block, and after seeing a small puddle of oil in the torque converter shroud, I'm suspecting a bad rear main seal. Any other possibilities? It's a 305 engine with about 104,000 miles by the way.
Old Oct 10, 2010 | 02:18 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
Re: rear main seal leaking?
Valve covers, Rear of the intake, between the block and intake, oil pressure switch or fittings, oil pan gasket. Valve covers can leak and the oil runs down the block and looks like it is coming out of the rear seal. You can remove the TC Cover and look up and see the rear main seal. might be able to confirm that the RM seal is leaking just by looking. Look up from below and see if the valve covers are leaking, if you see oil at the lower rear corners of the covers, they are likely leaking.
Old Oct 10, 2010 | 08:10 PM
Engine: LB9
I'll check those out, thanks!
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
