vacuum port question
Old Oct 10, 2010 | 02:47 PM
joe56's Avatar
Car: 91 Firebird
Engine: 383
Axle/Gears: 342
where is the best place to hook up the brake booster, on the back of the plenum or off the manifold,the reason I'am asking is I put a big cam in and the brakes are not working to well. I have it hooked to the plenum now I'am thinking of using a vacuum canister if there is no difference in connections.Thanks
Old Oct 10, 2010 | 06:08 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vacuum port question
That would be your problem.
Doesn't matter where you hook line up to; the vac is the same anywhere in the intake between the TB and the valve
beastin91rs
Oct 9, 2015 07:38 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
mx127
Aug 10, 2015 08:13 AM
