Engine Problem !!!!
Old Oct 14, 2010 | 09:31 AM
mattheat's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 305 Non Computer Edlebrok Carb
Transmission: Turbo 350
Axle/Gears: Original ones that came with car
Engine Problem !!!!
Was driving home from work and noticed that the car felt like it had alot less power, it has developed a popping from the carb now, there is also a tapping noise coming from somwhere at the top end any help would be appreciated thanks!!
Old Oct 14, 2010 | 12:59 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Engine Problem !!!!
I'd start by checking the oil. Make sure it's not low and there is no metal debris.
A screwdriver can be used to listen to various areas to help locate the source of the noise.
Pulling the valve covers might be an easy way to take a look around if you're sure it's coming from the top end.
Old Oct 14, 2010 | 01:30 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
What fireturd said. Look for a pulled out exhaust rocker stud or backed off nut.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
