White smoke coming from Engine
Old Oct 14, 2010 | 05:11 PM
BillyTheGoat's Avatar
Car: 1989 Trans am
I just got my car to start and I took it out for a spin. I only drove around the block but when I got back, I noticed white smoke coming from the front of the car. I opened the hood and there was smoke coming from the passengers side, it looks like its coming from the side of the engine or somewhere underneath. After the car was off, it kept smoking for a while, maybe 5-10 minutes. I noticed some oil on the bottom of the car, Could it just be oil dripping on the exhaust?
The smoke smells almost like burnt plastic. Some other important thing about the smoke is that it comes out by the carb when I accelerate. Also when I start the car and it smells weird almost like burnt plastic. I have a video of the smoke but I'll upload it later
I'm not sure if this has something to do with the smoke, but I have to pump the gas peddle to start the car and it doesn't start every time I do that
Old Oct 14, 2010 | 05:24 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
Re: White smoke coming from Engine
my wiring harness shorted last year, it passes thru the firewall on the passenger side, sounds like you have the same issue going on, tow it to a shop and check for a major short.
Old Oct 14, 2010 | 05:39 PM
Car: 1989 Trans am
There doesn't seem to be a short. I checked the oil and its good. The transmission fluid is way past the full level. I can see some small oil spots under the car but they are far apart .
Old Oct 14, 2010 | 05:43 PM
torque_is_good's Avatar
you need to pinpoint the origin as best as you can
Old Oct 14, 2010 | 06:05 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Could be valve seals? Not sure without you pinpointing it's location.
Old Oct 14, 2010 | 06:42 PM
Car: 1989 Trans am
I can't really tell, I'm going to drive it again later to see where it's coming from. I did notice more of the smoke was coming from under the distributor.
Old Oct 14, 2010 | 06:46 PM
PontiacMC's Avatar
Car: Trans Ams
sounds to me like you got oil from somewhere dripping onto the exhaust.
Old Oct 14, 2010 | 07:03 PM
Car: 1989 Trans am
that's what I'm thinking since it keeps smoking long after the car is off. I checked the oil and it's good. The PO mentioned he changed the oil dipstick tube and had a hard time installing it, I'm thinking he didn't do it right and maybe it's spilling some, the thing about that is that the oil level is good and theres not really any big oil spots, the spots I see under the car might have already been there
I looked at it again and the smoke seems to be coming from under the Exhaust manifold or at least around there, I don't have my ramps or I would've already tried to check the underside of the engine.
Old Oct 15, 2010 | 09:57 PM
Car: 1989 Trans am
I drove the car today maybe about 2 miles and the smoke didn't come back. When I put it back in the garage, I turned it off and turned it on to see if it would start without having to press the pedal ( it usually won't start without pumping the pedal a bit, I'll get to that problem later), it started perfectly. Then I turned it off again and started it, then that's when the smoke appeared. Also the belt area makes a a squealing noise when I rev it, it sort of sounds like metal on metal. I think the squealing is related to the smoke, I have a video of it revving with no noise and no smoke. When I rev it while it's smoking, the smoke puffs out, I can't see where it coming form though
After it started smoking again I saw that the carb was dripping fuel, I immediately turned off the car. I wanted to locate the smoke origin but it was too risky with the fuel. I have some pics of where the carb started leaking fuel. Another thing I should mention is that the oil smells like gas, Could gas be mixing with the oil causing the white smoke from engine? Should I replace the old carb, I don't even know what kind the carb is, it looks cheap though
Attached Thumbnails White smoke coming from Engine-fuel-carb.jpg   White smoke coming from Engine-fuel-carb-2.jpg
Old Oct 16, 2010 | 01:08 PM
Car: 1989 Trans am
I uploaded the videos of the smoke. The vids were taken with my phone
This first one shows around where it's coming from, sorry for the vid, I was holding a work light and my cell phone.
Old Oct 16, 2010 | 01:16 PM
Car: 1989 Trans am
This vid shows how the smoke comes out when I rev it a bit
Old Oct 16, 2010 | 02:21 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
You said that the transmission is over full. Is the fluid coming out of the tranny dipstick?
Old Oct 16, 2010 | 02:40 PM
Car: 1989 Trans am
I don't think so. It's about an inch or two past the "full" line, but it doesn't go to the top. I just remembered that when I start it smoke comes out near the carb, like on the vid where I'm revving it, but it smells weird almost like the smell a flint makes when you strike it
Old Oct 16, 2010 | 02:50 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Could it be you are pumping the excess trans fluid out the trans dipstick/filltube onto your exhaust? Not good to over fill a automatic trans.
Old Oct 16, 2010 | 03:18 PM
Car: 1989 Trans am
That's what I was thinking. That's how I got it, I've owned it for about 3 weeks. I just realized something, I drove the car normally yesterday and it didn't smoke until I took it back into the garage. The driveway to the garage is a bit steep, maybe it's spilling when I drive up into the garage. I don't know what type of transmission it has, The PO swapped engines, it has a 350 now and I don't know if he changed the transmission too.
I'm going to change the oil soon, I want to do a drain & fill of the ATF but I don't what kind I need and what transmission I have. I guess I can compare fluid pans but that would have to be until I get the car on ramps
Old Oct 16, 2010 | 06:09 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Look at the pan shape, and then you can tell.
http://www.nastyz28.com/chevy-transm...tification.php
Old Oct 16, 2010 | 07:52 PM
Car: 1989 Trans am
thanks for the link
Old Oct 19, 2010 | 10:42 PM
Car: 1989 Trans am
Here's a pic of the driveway, it's steeper at the beginning. Hopefully the smoke is just ATF spilling when I drive up. I'm still a noob at changing transmission fluid, I've only done a drain & fill on my last car which was a Honda civic and only required removing the drain plug bolt. How hard is it to change the fluid on T/A's?
Old Oct 31, 2010 | 12:00 AM
Car: 1989 Trans am
I found where the smoke is coming from, it looks like its coming from the cat. Could a bad cat make it smoke?
Old Oct 31, 2010 | 06:42 AM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Usually a bad cat gets VERY hot and makes the car run poorly. Any smoking would be because it is burning s*&t from being so hot.
Old Oct 31, 2010 | 04:18 PM
Car: 1989 Trans am
It does get very hot. I looked at it today after driving it about 10 miles and I could see the heated air around it. The car sometimes doesn't have a lot of power. I floored it a few times and it wasn't accelerating that well.
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
