I need to know where the knock sensor is located
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I need to know where the knock sensor is located on an 86 lg4 IROC is located. I want to replace it.
Re: I need to know where the knock sensor is located
IF it has one (not all LG4s do) it is in the coolant drain hole on the pass side of the block; halfway back on the block, just above the oil pan flange. It'll be just in front of the starter.
Thanks. I'll take a look. Is it easy to reach from under the car? I was planning on flushing the system anyway, so is this what needs to be removed to drain the coolant? By the way, this lg4 has a knock sensor. That was so GM could raise the compression ratio to 9.5 to 1
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
looks like a bell. Located underneath #6 and 8 cylinders on the passengers side of your block.Should have one single blue wire going to it.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Depends how badly its rusted into the block.
Car: 86 IROC-Z28
Engine: LB9
I've never had a problem removing one. Here's what it looks like:
I'll hit it with some PB Blast, and take it out. I guess I'll get some antifreeze coming out which is what I want anyway.
Car: 1990 IROC vert
Transmission: 700-R4
86CamaroDan
Sep 29, 2015 10:08 PM
