No real power?
Old Oct 15, 2010 | 04:13 PM
chefman45887's Avatar
Car: 89 Camaro RS
Engine: 283 SBC
No real power?
I got everything running right on my camaro its a 283 retro fit with a 700r4 behind it, the 283 isnt stock. Anyways just got insuance and tags and drove it around the block seems like it has no power when i try to drive it , im pushing close to 3500 rpms with no difference in idle ect. Also found out the speedo doesnt work even though i installed a new cable. any ideas or imput?
Old Oct 15, 2010 | 04:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: No real power?
Hard to say why it has no power without knowing anything about it, other than that it's a 283.
If you twist the transmission end of the speedo cable quickly, do you see the needle jump? If so, then check the speedometer gears. If not, make sure the cable housing is clipped into the back of the speedometer head correctly.
Old Oct 15, 2010 | 05:41 PM
Car: 89 Camaro RS
Engine: 283 SBC
Re: No real power?
checked speedo its fixed just feels like no power at the wheels when you accerlerate
Old Oct 15, 2010 | 05:48 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: No real power?
What do you mean about pushing 3500 with no change in idle?
The engine probably needs some attention to the timing and carb to feel right.
Old Oct 15, 2010 | 06:21 PM
Car: 89 Camaro RS
Engine: 283 SBC
Re: No real power?
when the car sits in the driveway at idle its 2500 i know its high but if i turn down the idle screw any more it idles off. when its in gear it drops down to 750 to 900 which is normal to me, but when i stop at stop sign at that rpms sounds like its gonna stall out. now when i drive the car a 1/4 mile down road im pushing close to 3500 with no real power change at the wheels.
im thinking not enough spark to burn the gas off plus maybe timing issues?
Old Oct 15, 2010 | 09:26 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: No real power?
What kind of carb?
Old Oct 15, 2010 | 09:58 PM
Car: 89 Camaro RS
Engine: 283 SBC
Re: No real power?
eldelbrock 500cfm performer with electric choke
Old Oct 15, 2010 | 10:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: No real power?
I'm thinking you need a new tach, for one.
How did you set the idle mixture?
Old Oct 15, 2010 | 11:13 PM
Car: 89 Camaro RS
Engine: 283 SBC
Re: No real power?
readjusted timing and idle, the tach is now at 1800 rpm reason it reads that because im going from a 6 to 8 cylinder setup , in due time a new tach.
runs like a champ now
BRoss99
Aug 10, 2025 05:08 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Reborn756
Sep 4, 2015 03:42 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
sailtexas186548
Aug 24, 2015 10:11 PM
