tach help?
Old Oct 19, 2010 | 01:17 AM
COTY'S IROC-Z's Avatar
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
tach help?
what color is the tac wire ..i thank it white but i'm not for shore! an does it have it own fuse?
Old Oct 19, 2010 | 01:49 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: tach help?
IIRC, it's white. There's no fuse.
Old Oct 19, 2010 | 02:33 AM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Re: tach help?
i plug mine up an i can git it to work are they a ground for it an were it if they are one?
Old Oct 19, 2010 | 09:37 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: tach help?
No dedicated ground for it.
Are you trying to get the factory tach to work, or an aftermarket one?
Old Oct 19, 2010 | 06:09 PM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Re: tach help?
factory i done the v6 to v8 swop with msn 7AL box i have tryed pluging it in to the msn box an on the distributor.. inty idea why it wont work?
Old Oct 19, 2010 | 09:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: tach help?
If you tried it on the distributor first, you've probably fried the tach.
Old Oct 19, 2010 | 10:06 PM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Re: tach help?
what can i do to fix it?
Old Oct 19, 2010 | 10:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: tach help?
Replace the tach
Old Oct 19, 2010 | 10:35 PM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Re: tach help?
well that sucks .. like when i start it in go up to 500 rpm an stays there
Old Oct 19, 2010 | 10:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: tach help?
500 RPM isn't your normal idle speed?
Old Oct 20, 2010 | 12:28 AM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Re: tach help?
if is was tor up it wouldnt do any thing would it?
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
