engine photos needed! show me your smog pump!! (82-85 only)
Old Oct 20, 2010 | 07:24 PM
SpiltTransFluid's Avatar
Car: '84 sport coupe
Engine: 355 .030 over 202 heads cam from RV
Axle/Gears: Idk, re is out of 93-97 V8
If anybody out there has an 82 to 85 with a 305, I could really use a photo or two of where your smog pump is located and how it is positioned. Nobody in my area has information on this. Thanks, all contributions greatly appreciated
Old Oct 20, 2010 | 08:08 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Re: engine photos needed! show me your smog pump!! (82-85 only)
The smog pump that was originally hanging on my block was located under the alternator. The lines for it haven't been connected in years,
Old Oct 20, 2010 | 11:10 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The smog pump is located on the passenger side on the bottom. With the brackets hooked up, it'll line up with one of the crank pully locations (can't remember which one). As I recall, it was on a single belt by itself. I swapped over to serpentine to aleviate the problem of the V-belts couple of years ago so my memory may be a bit fuzzy though.
Old Oct 20, 2010 | 11:19 PM
No you are right I've actually managed to dig stuff up on it. Now I just need some parts LOL parts which it also seems noone has
Old Oct 21, 2010 | 12:55 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
if you have a chevy dealer nearby you may be able to have them pull a diagram for you. We do that for people all the time.
Old Oct 21, 2010 | 01:00 PM
That would be nice because Haynes is about as descriptive as a Dan brown novel when it comes to emissions stuff lol
Old Oct 21, 2010 | 01:14 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Do you need to see how the pump itsself was bolted onto the brackets, or how the air diverter and hoses were? This is the best I have for a front view of the setup. Sorry the bottom of it was cut off because of the angle I took the picture. The belts removed in this picture, along with the vacuum line that goes to the air valve. Took all this stuff off months ago so cant get a new pic. I have one or two side views though.
Old Oct 21, 2010 | 01:24 PM
Sparkytfl's Avatar
Old Oct 21, 2010 | 01:34 PM
Thanks man that's exactly what I was looking for! Do you still have the brackets and v belt pulleys for all that? If you do, I have money lol
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
