Firebird headlight issues…
Old Oct 25, 2010 | 07:41 AM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
Hello everyone,
I have a 1991Pontiac Trans Am with two head-light issues:
1) The head-lights pop up (but do not turn on) when I turn on the parking-lights. I replaced the dashboard light switch originally thinking this was the cause; however it did not remedy the situation. They do turn on when I press the head-light button.
2) One of my headlight motors would appear to be going as it flutters when going up and sometimes drops back down. Motor turns longer than the other side which seems to be working as normal. As these motors are difficult to come by, is there another vehicle which has a motor which might work?
Any and all feedback is greatly appreciated!
Thanks,
Jim
Old Oct 25, 2010 | 08:03 AM
GTA88's Avatar
Re: Firebird headlight issues…
Jad,
As far as the headlight motor goes, there is an "easy" fix for it. You can replace the nylon bushings (bearings?) inside the motor, and they work like new. Cheap fix, just takes your time for labor. I have to do it for both my headlights ( 88 GTA) but haven't gotten around to it yet.
Good Luck
Old Oct 25, 2010 | 09:28 AM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Go to the website "Top Down Solutions" for your headlight rebuild kit. Very straightforward and a good price.
Old Oct 26, 2010 | 06:51 AM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
Hey guys, thanks for the info... should have thought about the rebuild kits myself as the ebay headlight motors are quite pricey.
Any thought on the Parkinglight - Headlight pop up issue?
Thanks,
Jim
Old Oct 26, 2010 | 07:13 AM
jwande's Avatar
Engine: 305 TBI
First, on all things electrical, I check the fuses. I have spent too many hours only to find a blown fuse. There will be a relay somewhere, and that is where I would start on the other issue.
Old Oct 26, 2010 | 01:11 PM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
Under dash fuses are all good. Any idea where the headlight relay is or how to tell if it is still good?
Thanks,
Jim
Old Oct 26, 2010 | 07:20 PM
gta90's Avatar
Car: 1990 GTA (T-Top)
Engine: 305 TPI (LB9) / 115k miles
Transmission: 4L60 (MD8 non-E)
Axle/Gears: 2.73 (GU2) 28 spline POSI (G80)
If you buy the TDS kit, good luck following the instructions. You'll need it!
They contain pictures that don't really help any, and don't contain pictures that are desperately needed.
Also, count on the motor housing nut heads to break off when you open up the motors. Id get some reverse threaded drill bits ahead of time.
1992 Trans Am
May 10, 2023 07:19 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
