Replacing a lifter, found something different....
Old Nov 7, 2010 | 03:00 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys, I have a thread going about how I have had a ticking lifter.
Well.... I pulled the offending lifter to replace it and it doesn't look like any lifter that I have seen before. Here's what I'm talking about. The lifter on the right is the one out of my engine, the lifter on the left is the replacement.
bottom is from the engine top is replacement
Black is from the engine silver is the replacement
From doing a little research the one from my engine is similar to a LS7 lifter. Would replacing this lifter with a stock one cause any problems? Help me guys!!! I need the car back together so I can go to work tomorrow!!!
Old Nov 7, 2010 | 03:33 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Replacing a lifter, found something different....
I would say as long as you are replacing it with a stock lifter that is the same in all aspects, you are fine. Check length and diameter to be sure and if they match, shouldn't be any issues. The differences of the lifters in your photos could be because of different manufacturers.
Old Nov 7, 2010 | 05:37 PM
The only problem I have seen is that the plunger on the "black" lifter is a touch deeper than the replacement lifter. Can I get away with just cleaning the old lifter and reusing it?
Old Nov 7, 2010 | 05:52 PM
jtsk's Avatar
You MIGHT get away with it, but I wouldn't chance it. If the new one is just a touch deeper it shouldn't matter as you will have to adjust your valve anyway once you put it back together.
Old Nov 7, 2010 | 05:59 PM
actually the new one is more shallow and is seems that the old "black" lifter has a stiffer spring than the new one.
Old Nov 7, 2010 | 06:19 PM
jtsk's Avatar
well probably it is just a difference in the manufacturer. If you bought a stock replacement, you should be fine.
Old Nov 8, 2010 | 02:24 PM
So can any body tell me what kind of lifters I have? If it's an LS7 lifter what are the specs of it? The engine is a scoggin dickey reman from 2001. So it's the lifters that have been in since I got the car. EDIT.......ok I just got off of the phone with John at scoggin dickey and he tells me that every engine since 2000 has been sent out with LS7 lifters. So I guess I need to buy a set of those. DAMN!!!!! Will I be able to just get by with cleaning the lifter until the set gets here? I already did it and it pumped up fine afterwards.
Old Nov 8, 2010 | 06:55 PM
jtsk's Avatar
I have never cleaned a noisy lifter and reused it and don't know of anyone else who has either. I'd be wary of it myself, but that just might be my paranoia.
gta90
Sep 15, 2015 04:00 PM
ChevyZ71
Aug 13, 2015 07:30 AM
bjpotter
Aug 12, 2015 06:06 PM
marcusaw
Aug 10, 2015 08:13 AM
antares57
Aug 6, 2015 07:47 AM
