clogged injector cleaning?
Old Nov 7, 2010 | 08:03 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I havent started mt lt1 swap camaro in 6 years and i went out today and hooked up some wires and tried to start it.. naturaly it ran horrible as expected. I flipped the fuel rail and found that only 2 of the 6 injectors aer working. whats the best way to clean them.. or what parts vehicles can i get some from?
thanks!
Old Nov 7, 2010 | 08:18 PM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Re: clogged injector cleaning?
Do you have fuel pressure? I would guess the pump would be bad after sitting for 6 years.
I have heard that some shops run Seafoam in their pressurized injector cleaners.
Go to Rockauto.com and look up your injectors. Then you can hit the "info" button and it will tell the make, model, and year of cars that part number fits. Those will be your donors.
Old Nov 7, 2010 | 08:23 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
lots and lots of fuel pressure, almost like a garden hose when i take the line off. The tank was dropped when the car was painted and a walbro was installed. today was actually the first day the walbro has ever been submerged. The injectors on the other hand are caked with varnish. damn thing ran on 2 cylinders too! its unbelievable.
I might be buying new bigger injectors later if i cant get these to work. I dont have much money now, so for now Its a must i get these to work.
Old Nov 7, 2010 | 10:31 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Your best bet is to have your injectors professionally cleaned & evaluated, way cheaper than buying new, much better than trying to clean them yourself (fail).
http://www.witchhunter.com/
http://www.injectorsplus.com/
http://www.southbayfuelinjectors.com/
Old Nov 8, 2010 | 07:44 AM
southbay08's Avatar
Seafoam is a great product, we sell it. But in a case like this, 6 years?? honestly i wouldn't bother using a fuel injector cleeaner. Even if it does work and your injectors open up, you are not going to be able to evaluate the result...ie spray pattern, leaks, etc. I agree with xch3no2, you should have them professionally cleaned, flowtested, and evaluated by any one of us, and then you can take it from there.
We will be more than happy to check them out for you.
bryan623
Mar 22, 2021 06:43 PM
Infested
May 22, 2018 11:56 PM
Justin92GTA
Aug 27, 2015 11:16 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
