bad noise when trying to start
Old Nov 9, 2010 | 05:25 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
if the battery is fully charged after a few seconds of cranking the voltage gets dragged down rediculously low.
Also everytime I crank the engine about every 2 seconds it makes this awful grinding noise. It won't start. what's wrong with it?
Old Nov 9, 2010 | 08:10 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: bad noise when trying to start
Sounds like your starter is bad.
Old Nov 9, 2010 | 11:14 PM
Firebirda7x's Avatar
Car: 1986 Firebird Trans Am
Engine: Chevy 355
Transmission: Built 700R4
Axle/Gears: 9 bolt 2.77
How low does the voltage get? It is normal to have a voltage drop of about 2-3 volts when starting, but it should return when the alternator kicks in. If the battery has a bad cell you aren't supplying the starter with the proper voltage to fully turn over and it can burn out.
Old Nov 10, 2010 | 11:21 AM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Just a quick check - turn on your headlights to start the car. If the lights go out, you have insufficient power. If they don't, you have starter issues. This isn't foolproof, but it will help you narrow down your next troubleshooting step - get your battery tested.
Old Nov 10, 2010 | 11:30 AM
0pyders's Avatar
headlights are good.
I tested the battery and the voltage was normal.
I looked at the flexplate and you can see scratches from the starter hitting it.
I don't know what to do next.
Old Nov 10, 2010 | 11:57 AM
Engine: Chevy 355
Did the flexplate ever make a knocking or tinking noise?
Old Nov 10, 2010 | 11:59 AM
0pyders's Avatar
Nope, I just hear a metal grind.
Old Nov 10, 2010 | 12:52 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
How old is your starter? After I replaced my starter, the starter gear that turns the flywheel had a couple of bent teeth. That was the cause of my grinding noise on start up. Went away with the new one. Luckily the flywheel was still in good shape.
Old Nov 10, 2010 | 01:34 PM
0pyders's Avatar
Starter is new.
The noise is the same as when you try to crank the engine when it's already on.
Old Nov 10, 2010 | 04:01 PM
0pyders's Avatar
figured it out needed shims...
Old Nov 10, 2010 | 07:57 PM
0pyders's Avatar
No wait still having problems...
After the engine is cranked, that gear on the starter that moves the flexplate stays in the same position after I stop cranking.
The scratches on the flywheel teeth are only done on the left side (toward front of car).
After putting shims on the starter it still made the noise. Then I tried loosening the 2 bolts a little and it did it even more constant. Help me before I accidently destroy this car.
Old Nov 10, 2010 | 08:18 PM
red rock's Avatar
Car: 1987 iroc
Either your new starter has a bad bendix or you have a binding problem.
theshackle
Sep 17, 2020 08:26 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
