Circle Track Dirt??
Old Nov 17, 2010 | 12:13 PM
Pushinthecushin's Avatar
Circle Track Dirt??
After a couple years of not racing I just started building a 92 camaro pure stock. I have seen a few of these run and they are wicked fast on dirt. Has anyone had any luck? I already ditched the stock torque arm and pan hard rod and put links in.
Old Nov 18, 2010 | 08:55 PM
Re: Circle Track Dirt??
Its hard to believe NOONE has tried one of theses!! I raced one once.. Wicked fast entering ... pushibg in middle loose off..started 20th finished 5th! Someone has to have done it other than me!
Old Nov 18, 2010 | 09:05 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Old Nov 18, 2010 | 09:06 PM
mightymaro94's Avatar
seen some guys do it... montes are the big thing here on dirt tho
Old Nov 18, 2010 | 09:50 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
I've got some tickets for the USMTS Winter Nationals. This weekend at:
http://www.houstonraceway.com/
I've seen a few of the F-Bodies on dirt, very fast indeed!
Old Nov 18, 2010 | 10:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It really depends on the class of racing. Many lower oval classes have banned f-bodies because they have an advantage. G-bodies are more common. With a full frame vehicle, they can take a lot more abuse and suspension/driveline/chassis is easier to repair.
Old Nov 19, 2010 | 09:08 AM
U
Old Nov 20, 2010 | 06:54 AM
Well, these cars have only been around for about 29 years now, and even though for much of that time they were the ONLY performance oriented cars from GM besides the Vette, I doubt ANYONE associated with racing has ever noticed them; and since their resemblance to "late models" is so subtle, I doubt anyone anywhere at any time has ever made that connection, either...
So,,,, .... ummm,,,, ..... yeah......
Where I come from, "pure stock" means PURE STOCK. Which in the case of these cars means, if you get challenged and they catch you with a 4-link under it, you get bumped into some other class; probably late models in fact. Don't bet on participating in many "level playing field" events with it unless EVERBODY in that class at that track is already allowed to run that setup, in which case you won't have any advantage for long.
Old Nov 20, 2010 | 09:17 AM
They are starting to allow these cars at a lot of tracks now. G Bodies are getting harder to find for a descent price. You can find third gens everywhere. Cheap. I am allowed to run it as long as no 5 speeds. So I went with an MC-1 Muncie 3 speed. They said I could put links for TA and pan hard so I did. I must weigh 3400lbs though. Plus 50 more for the 602 crate. Car is awesome though. I think it will be just a matter of a few weeks and I will be the car to beat. Then I suspect they may outlaw again after I walk the dog on them a few times. The hardest part was getting caster and camber and ackerman right using stock stuff. I run 2.5" of stagger in the rear and 1.5 in front. Using DOT tires.
Old Jan 19, 2012 | 02:44 AM
Motorheads75's Avatar
I have built and raced two 3rd gen's and over this winter I have begun my third,I personally will never build any other type of chassis because these things work freakin amazing! I hope to share my knowledge of building and setup,remember these things were designed to handle,leave granny's swayin grocery getter Monte at home!
Old Jan 19, 2012 | 04:22 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Around here I started out running 2nd gen camaros, Then I had a 84 Camaro for awhile. Now everyone runs G body cars though.
Old Aug 19, 2014 | 02:52 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Im going to bump this since I rarely see it mentioned on here.
Local 1/2 mile track just started a new pure stock class where 3rd gens are legal. Curious if anybody on here currently or has dirt tracked one before.
Old Mar 12, 2015 | 12:07 AM
r.fulks's Avatar
Car: 88 firebird 2.8 to 5.7 swapped
Engine: goodwrench 350 (made in mexico)
Transmission: currently running a th200
Axle/Gears: 3.73 (v6 stock gearing)
I race a 88 firebird in a pure stock type class, though it's called "street stock" the rules are very similar. Car started as a bone stock 2.8 mpfi. I ran it with the v8's, as there is no 6cy class, for a season and the car ran great! very competitive. A 350 now sits under the hood, backed by a th200 and am working on tuning on tuning the suspension.. its work in progress.. haha
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
jaridjohn
Oct 5, 2015 07:01 AM
Numbah-1
Oct 2, 2015 08:27 AM
