smoking overheat no start after (tpi)
Old Nov 20, 2010 | 06:55 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
ok so i bought an 88 iroc recently because i didnt like the amount of rust on my berli. the guy told me that the car sat for at least a year but he would go out and start it from time to time. now as i was driving home from the marines the car started to over heat so i turned the ac on hoping it would cool it down so i could make it home well driving down the garden state parkway my car started smoking and lost power and died when i got it home i tried starting it and it would turn over but no start......today i went outside and checked for a blown coolant line but they were all good and i swapped out the over flow bottle... i also installed the MSD that i had into the car plus a new coil just not the dizzy yet i am getting spark to the plugs and i smelled fuel, the pump is on i can hear it but it will not start any help?
Old Nov 20, 2010 | 08:18 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
Re: smoking overheat no start after (tpi)
you have to turn on the heater in an overheat situation, but check the wiring harness, mine shorted and burned up about a year ago, it was at the fire wall.
Old Nov 20, 2010 | 08:25 PM
Airborne11b's Avatar
Car: 1991 Camaro RS T-top
Its a very common problem in 3rd gens but the reason it wont start after and overheat its safety mech in the computer to keeo from damaging the engine give it some time and will restart but you can do a search in the forums for the problem but it is sensor related
Old Nov 21, 2010 | 09:19 AM
Axle/Gears: stock
yeah thats what i was told but what sensor other then the cts? and its weird that i am smelling gas and getting spark i am going to swap out the cts either today or tomorrow hopefully someone knows the sensors that cause this
Old Nov 21, 2010 | 05:57 PM
Axle/Gears: stock
after further inspection i have found out it is not a 350 but a 305...i have a 350 build slowly coming along does the motor have to be a roller in order to use tpi?
Old Nov 21, 2010 | 06:31 PM
alittle off topic but where in Nj I lived there my entire life until the army shipped me out to KY
Old Feb 9, 2011 | 06:54 PM
Axle/Gears: stock
im in north jersey around wayne and paterson
bryan623
Mar 22, 2021 06:43 PM
Wade787b
Sep 29, 2015 01:15 PM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
