Easy Question
Old Nov 21, 2010 | 02:40 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Easy Question
I'm starting to take out my engine today. Its an lb9. I was just curious, when I unplug the fuel injectors does each connector need to be labeled so I don't plug in a connector to a wrong injector when I hook everything back up later? Thanks
Old Nov 21, 2010 | 03:00 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Easy Question
I would say yes.
Old Nov 21, 2010 | 08:22 PM
bigj350's Avatar
Re: Easy Question
I was thinking every injector fired at once so it wouldn't make a difference. Oh well, it's not a big deal. I was just curious.
Old Nov 21, 2010 | 08:34 PM
mightymaro94's Avatar
Re: Easy Question
its got 8 injectors right?
Old Nov 21, 2010 | 08:39 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Easy Question
Correct
Doesn't matter
The way the engine harness is laid out the worst you can do is swap 2 injector plugs on the same bank which would have no effect because all 4 in the bank fire at once
Old Nov 21, 2010 | 08:49 PM
Re: Easy Question
Originally Posted by vetteoz
Correct
Doesn't matter
ok im not a tpi guy but i would assume that they cant all fire on the same bank at the EXACT SAME TIME... bc all the pistons on that bank are not on the same stroke at the same point at the same time and the injectors should fire similar to the ignition
Old Nov 21, 2010 | 08:54 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Re: Easy Question
The difference between batch fire and sequential? no i cant remember the other one. Well anyway batchfire is one entire bank at a time so its not as efficient as each individually.
Old Nov 21, 2010 | 08:59 PM
Re: Easy Question
gotta admit never heard of batch fire.... seems very very counter effective... so lb9 is batch fire?
Old Nov 21, 2010 | 09:02 PM
Car: Camaro RS
Re: Easy Question
honestly i have no idea i know tpi and older lt1s are so it probably is
Re: Easy Question
ok lookin it up looks like its batch , semi sequential and sequential... obdII would be sequential ... im still learnin ... this is interesting that such a crappy idea woulda been put into such great cars lol
Old Nov 21, 2010 | 09:13 PM
Car: Camaro RS
Re: Easy Question
Ya i know not really much more efficient of a fuel delivery system than carbs lol. but still fuel injection so hey
Old Nov 21, 2010 | 09:18 PM
Re: Easy Question
btw vetteoz that was by no means a personal attack on you... it jus didnt make sense to me... to be quite honest it still dont lol but i do understand a little better now
Old Nov 22, 2010 | 02:02 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Easy Question
Things are happening so fast in the engine that an injector can fire even if it's not at 'exactly' the right time and the fuel charge will get sucked in 'in the blink of an eye'. Or even faster. It's too late to do the math but you could calculate the time between firings and see the max time the fuel would need to wait. Maybe the sequential system just isn't worth the extra effort (and cost?) unless everything else is perfect.
Old Nov 22, 2010 | 06:29 AM
Re: Easy Question
well im guessing it is worth the extra effort since obdII cars got sequential
lol
Old Nov 22, 2010 | 06:54 AM
bigj350's Avatar
Re: Easy Question
Correct
Doesn't matter
Thats what I thought. Thanks
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
BurlyChev
Aug 16, 2015 09:08 PM
