power steering set up
Old Nov 22, 2010 | 10:06 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
I have a 1992 firebird with a 79 350 sbc in it and i want to use power steering. will a third gen bracket just bolt up to my motor and i can use the 92 pump and lines?
Old Nov 22, 2010 | 10:32 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: power steering set up
if you swap all the brackets and accessories (crank pulley, alt, water pump), everything will work. however, depending on the heads, you may not have provisions for the mounting bolts on the passenger side head. I ran without these bolts in place for a couple years, but someone else may want to chime in about its reliability.
Old Nov 22, 2010 | 10:47 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
i cant run the 92 bracket and pump and the pulley from a 79 pump?
Old Nov 22, 2010 | 10:59 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
IIRC, the pulley from the 79 pump would be for a v-belt setup, while the pulley from a 92 is a serpentine belt style. The pump should bolt up to the bracket, and the bracket should bolt to the block, but you will need to use the serpentine setup.
Old Nov 22, 2010 | 11:00 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Old Nov 22, 2010 | 11:17 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I should add that either pulley will fit the pump. They are all the same. Its the brackets and belts that changed over the years.
Old Nov 22, 2010 | 11:46 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
well im running a vbelt setup so ill need the v pulley
Old Nov 22, 2010 | 02:34 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
If you're running v-belts, you'll need the pulley and the brackets. The steering pump should be the same.
The 92 bracket should bolt up to the engine just fine, but I don't think the pulley would line up properly with the crank pulley. You also would have no way to adjust the belt tension or to change the belts without removing the crank or steering pulleys.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
