1986 Camaro engine swap oninions please
Old Nov 26, 2010 | 08:13 AM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Transmission: TH 700R4 or TH 7004R
Axle/Gears: Moser 9" 370:1
Is it easier to install both the tranny and engine at the same time or just the engine and the trans later, 350 Th700. Thanks for you opinoin,
Steve
Old Nov 26, 2010 | 04:22 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Re: 1986 Camaro engine swap oninions please
IMO engine first then trans from the bottom. Less to wrestle with on the hoist that way.
Old Nov 26, 2010 | 05:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If the 1986 tranny has never been rebuilt, I'd pull both together as a unit. Then I'd get a 1988 or newer 700R4 (they made significant changes in mid 1987 years), have it rebuilt, and put entire drivetrain back in at once. ESPECIALLY if this is a 305 car - many of us find that as soon as the 305 is swapped for the 350, the tranny slips almost immediately behind the 350, where it was fine behind the 305 - because the 350 is so much more powerful - the 700R4 can act fine until it gets that extra hp in front of it. I pulled my 305, put in 350 - and on first test drive, barley got 2 blocks back to the driveway because the tranny slipped so badly behind the new power. Might as well just do it at once and make it easy.
Old Nov 26, 2010 | 10:09 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Two good points, but with the equipment I have (stands on 2X12s on the ground) it was very hard for me to get the trans matched up. So far the trans that I "think" has been replaced and is spotless inside has handled 6 pounds of boost with no problem, plus, I have a spare 700 that was rebuilt for me with very good parts, or so I was told. I'm pulling the engine and I do not want to fight the trans on my back. If anybody else gas any opinions, please let me know.
SPK
Old Nov 26, 2010 | 11:05 PM
d_stack's Avatar
Car: 1990 iroc
Engine: 5.7 vortec
Axle/Gears: 4.11
personally if you want both out, pull them out together . yes u gotta wrestle with motor/tranny but its alot faster and less layin on the ground work.. i took out my 85 305 motor out my car and put a vortec 350 and that 700r is doing fine
Old Nov 27, 2010 | 06:33 AM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Old Nov 27, 2010 | 07:05 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I would pull both together. If you have a good hoist its not a problem, some of the small cheap hoists don't handle the extra weight very well.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
