Mid mount alternator bracket?
Old Dec 1, 2010 | 11:13 AM
87350IROC's Avatar
Car: 87' IROC
Guys,
I have the '87 hybrid v-belt setup with alternator on the passenger side. I am not currently running an AIR pump and would like to mount the alternator in roughly that location. I have not seen a lot of info on brackets that work with these cars. Has anyone done this?
Old Dec 3, 2010 | 03:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't recall having seen anyone who has done it. You'd have to fabricate brackets, I'm sure.
In fact, you might check the Fabrication forum. I don't spend much time there, but perhaps someone has tackled it.
Old Jan 21, 2011 | 12:22 AM
87350IROC's Avatar
Car: 87' IROC
Re: Mid mount alternator bracket?
I found one that might work. March Performance 20124.
Old Jan 21, 2011 | 12:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Just about any mid-level alternator bracket should work - you'll just have to change belt size. You have the wide belt for alternator, and V-belt for P/S and A/C right? I swapped my Serp setup for a setup like yours - putting alternator back on pass side where it belongs, and I got rid of smog and A/C.
Alternator brackets seem to be easy - even the lower priced brands seem to work well - you could check ebay or other brands and save some cash over the March. But if you ever do anything with P/S, stay away from anything other than March - I tried several different ones that 'looked' identical to the March P/S stuff, but the ONLY one that worked properly was the March.
Old Jan 21, 2011 | 01:21 PM
87350IROC's Avatar
Car: 87' IROC
Cool. I had a little trouble finding one that I was sure would fit my alternator. Yes I am sure I will have fun finding the right part number for the belt.
I already ordered the March, I will post up pics when its done.
I would love to get rid of A/C as that would really clean up the engine bay. But the few times a year I use it, its nice to have.
Thanks for the info.
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Genopsyde
Nov 11, 2015 10:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
