non computer controlled hei
Old Dec 4, 2010 | 06:22 PM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
I am rebuilding my sbc and pulled an hei from a 78 chevy truck. It looks exactly the same as my stock one excpet for the vacumm cam. I would like to get rid of the comupter under the passenger side dash, so I need a non computer comtrolled hei. I already got a holley carb. Anyone know where I can buy one, got any pics so I can see what they look like. is the hei in the link non -computer controlled. heres the link: click here
Old Dec 4, 2010 | 06:28 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: non computer controlled hei
That is a non-computer-controlled HEI.
Old Dec 4, 2010 | 06:43 PM
MikeSammy's Avatar
can someone post pics of both a non-computer controlled hei, and computer controlled hei so I can see the difference thanks
Old Dec 4, 2010 | 07:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There are no external differences, aside from the vacuum advance can.
Old Dec 4, 2010 | 09:01 PM
MikeSammy's Avatar
Would I have to hook up the two wires from my car into the distributor, or can I just drop it in and the car will run? I think one wire is for the rpm tach and the other is for the computer
Old Dec 4, 2010 | 09:16 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
CC one has a large flat plug with 4 wires from the base as well as the 3 wire plug to HEI cap
Non CC only has the 3 wires to cap
Of course you have to hook it up to something otherwise dist will have no power.
Wires connect exactly the same as on CC unit .Pink wire is power , white is Tacho
The computer connects on the 4 wire plug which you won't have with a non CC dist
Old Dec 4, 2010 | 09:21 PM
MikeSammy's Avatar
how does the vacuum advance can work. Do I hook it up to the carburetor
Old Dec 5, 2010 | 05:30 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The vac can changes the dist advance as engine load changes because engine vac changes in relation to load
Low load ( cruise / idle ) = hi vac ; lots of advance.
Hi load (WOT )= low vac ; so less advance
There is a port on the carb for the vac line to dist
Old Dec 5, 2010 | 03:49 PM
MikeSammy's Avatar
Can I hook this up to any vacuum port on the carb or is there a specific one?
Old Dec 5, 2010 | 05:38 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Bottom of page
http://www.gofastforless.com/ignition/advance.htm
Old Dec 5, 2010 | 06:58 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Distributor vacuum should be taken from from the intake itself.
My '86 Silverado 305 takes it from a T-port on the manifold directly behind the Brake booster vacuum connection.
If you have to get it from the carburetor be sure the port is below the throttle plates.
Old Dec 5, 2010 | 09:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No difference taking it from a full-time vacuum port on the carb, or from the manifold.
Ported vacuum is fine, but cars with larger cams will idle better with full-time.
Old Dec 6, 2010 | 12:14 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
My understanding of ported vs manifold vacuum is that ported vacuum increases as manifold vacuum decreases this is why ported vacuum is used for EGR control, manifold vacuum is weak at the rpm required for EGR, which is opposite of how the distributor works.
Having said that, I only stated it for emissions/economy purposes.
Old Dec 6, 2010 | 08:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's a common misconception, but they don't work like that. Ported vacuum is drawn from a port above the throttle blades, so there'a no vacuum on it until the throttle is opened past that point. After that, it behaves the same as manifold vacuum.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
