broken engine mount bolt
Old Dec 4, 2010 | 09:13 PM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
I was putting engine mounts on my chevy 350 today. I got two of the 3 tight but the third ( the top left one ) would not get tight so, I continued to tighten and the head broke off of the bolt. Will the engine be okay with just two bolts holding to mounts on or could I redrill it and put anouther bolt in its place. If so, what tools will I need to redrill it.
Old Dec 5, 2010 | 02:32 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: broken engine mount bolt
I would think you would be fine unless you are racing it. You could always re-drill too, but you might want to try a thread chaser first and a new bolt, that would be easier than re-drilling.
Old Dec 5, 2010 | 02:47 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
EDIT: Sorry, I misunderstood the problem.
JamesC
Old Dec 5, 2010 | 03:48 PM
MikeSammy's Avatar
The bolt is actually broken off into the block, so I don't think a thread chase will work.
Old Dec 5, 2010 | 04:20 PM
jtsk's Avatar
Is there any chance you can get a pair of vice grips on it enough to back it out? If not, you can drill it and use an easy out to remove it.
Old Dec 7, 2010 | 06:49 PM
MikeSammy's Avatar
bump for more suggestiong. Basically will the engine be okay in the car as is. I don't plan to race it alot just probably 4 times a year and a lot of high revving to show off teh sounds of my flowmaster
Old Dec 7, 2010 | 07:37 PM
jtsk's Avatar
If the other two are tight, you should be fine.
Old Dec 7, 2010 | 10:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Which side of the engine are we talking about?
Old Dec 8, 2010 | 02:43 PM
MikeSammy's Avatar
the passenger side of the engine. I was thinking of using an easy out as jtsk. When I was putting the harmonic balancer bolt onto the crank snout that snapped as well so I could use an easy out for both of them.
Old Dec 8, 2010 | 06:10 PM
five7kid's Avatar
The passenger side mount bolts don't take as much tension loading as the driver side, as long as you aren't downshifting hard.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
