HELP!!! CHECK ENGINE LIGHT READS ERG,OXY SENSOR,MAF/MAP too HIGH!!
Old Dec 11, 2010 | 01:44 PM
Daapunk's Avatar
Car: 88" Trans am
Engine: 350 bored. 383 Stroker Kit
Transmission: Power Glide
Axle/Gears: 4:10
hey guys my check engine light has been on a while but my car has been sitting up so i havent had the time to work on it here during the summer, work has had me busy and wish my first child this year. Well i fired her up and she runs but chugging and stalling at first then after a sec or two the rpms raise and she runs a 1100-1200 idle for little then goes down, but my engine codes read EGR failure, Oxygen sensor, and MAF/MAP too high...I Found one vaccum leak on a line fitting going to a sensor on the passenger side... what sensor is that and where should i go to begin fixing these problems and which ones would u replace first??? HELP PLEASE car is getting horrbile gas mileage also.
Old Dec 11, 2010 | 04:44 PM
Daapunk's Avatar
Car: 88" Trans am
Axle/Gears: 4:10
Re: HELP!!! CHECK ENGINE LIGHT READS ERG,OXY SENSOR,MAF/MAP too HIGH!!
HELP!!!!
Old Dec 12, 2010 | 01:44 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Is this a TPI?
Old Dec 12, 2010 | 02:42 AM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Definitely take the planum off and check all of the vacuum hoses going to your EGR. If that doesn't fix it, get a new EGR.
Old Dec 13, 2010 | 08:19 AM
Daapunk's Avatar
Car: 88" Trans am
Axle/Gears: 4:10
Yes 305 tpi, i have breather on top. fuel injected.
Old Dec 13, 2010 | 02:30 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The component on the passenger side which looks like a sensor is probably your EGR solenoid. By replacing the hose you may have fixed that problem. I do not recommend pulling your plenum to check EGR. You can test EGR with a vacuum pump from the hose at the solenoid. First clear codes and see if the code comes back after driving. The O2 and MAF(your 88 is a MAF car, not MAP)codes can both be caused by vacuum leaks. Youve repaired one already, look for others. You have an aftermarket air intake tube? Check all the tube connections for leaks. Especially look for leaks between the MAF sensor and the engine.
Old Dec 13, 2010 | 02:34 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Forgot to mention, your symptoms sound alot like a stuck open EGR valve. Try manipulating the valve with a vacuum pump. With vacuum applied to the valve at idle the engine should shudder and stall. If not, the valve is probably stuck open.
Old Dec 14, 2010 | 05:51 PM
Daapunk's Avatar
Car: 88" Trans am
Axle/Gears: 4:10
man ASE i sure thank you for helping me out. On my car i cant seem to find a MAF like as shown online. on my intake snorkel there is a vaccum line going to some type of flapper on the snorkel.... i dont see a MAF sensor..... yea i fixed a vaccum leak going into the egr solenoid i guess thats what it is, the rubber connecter had dry rotted and split. car still jumps and stalls on start up then rpms raise and runs ok after few seconds after first start up.
Old Dec 14, 2010 | 10:04 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
A picture of your engine would help.
There no intake snorkel's with flappers on '88 TPI.
If there's is then I'm missing that and the snorkel.
Old Dec 17, 2010 | 05:30 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
What you are describing is an air cleaner as would be found on either a carbureted or TBI car. In which case, you dont have a MAF(mass air flow sensor). You have a MAP(manifold absolute pressure sensor). Your car is speed density. The MAP should be either on the rear corner of the air cleaner or on the front edge of the cowl. You can identify it by the green, 3 pin connector and a single, hose. Its rectangular and a bit larger than a Zippo lighter.
Did you check your EGR valve yet? Yours will be on the intake manifold beside the throttle body. You can manipulate the diaphram by squeezing it with your fingers. Check to see if its stuck open.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
