Gauge Help!
Old Dec 11, 2010 | 10:04 PM
Kozusnik's Avatar
Car: 1986 Sport Coupe Camaro
Engine: V6 2.8L vin S 173ci - MFI GAS
Transmission: 5 Speed Manual
Gauge Help!
will any of the third gen camaro's gauges work in any thirdgen camaro? I have a 1986 Base and i am wanting to change my gauges from the one with the BIG fuel gauge and speedometer and the three idiot lights... To the one with the big tach and all....
Please Get back to me asap....
Old Dec 11, 2010 | 10:35 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Gauge Help!
to be honest you should just pul up the wiring diagrams for your car and for the car its coming out of and compare them
Old Dec 12, 2010 | 02:58 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Gauge Help!
As far as I remember, the Camaros, before the electronic speedo, all had analog gauges. You will have to run a wire to the tach connector under the hood to operate the tach. You will also need to swap out your warning light switches(oil, coolant temp) for sending units. Otherwise you should be okay with any cluster before 89. Just to be sure, verify a mechanical speedo on the one you buy. DITTO on referring to the factory wiring diagram when making changes.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
