another rigged camaro...
Old Dec 12, 2010 | 12:23 AM
Flipsyde's Avatar
Ok so can anyone tell me what i should do in order to run codes, when my OBD port has bout 3 wires coming out the back and the codes dont even scan? its annoying having to test everything by hand, whats the point in having a computer if doesnt tell you anything?
Old Dec 12, 2010 | 12:52 AM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Re: another rigged camaro...
You have to have an OBD I code reader to get the codes...if that's what your asking?
Old Dec 12, 2010 | 01:05 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
What year is the car? Only later model cars have a few wires at the OBD-II port, usually at least power, ground, and data for the scantool. Earlier ALDL ports have quite a few wires for testing things like the fuel pump and such.
If you have an OBD-II based PCM (96 and above), you will need a scantool, or at least a basic code reader from the local autoparts store. Cant just stick a paperclip in those.
Old Dec 12, 2010 | 01:10 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello dimented24x7!!
I saw on the net, some place was saying that the paperclip at terminals 5/6 worked..........with an OBD 2 connector on an OBD 1 emission system equiped Camaro!! Basically 1995 Camaros!!
Old Dec 12, 2010 | 01:16 AM
Car: 88 Camaro SC
Engine: SFI'd 350
The 96 and up only have serial data at the OBD port. DONT stick anything in these. Theres +12 volts and ground, so you could cause a direct short. 95 and earlier are still OBD 1/1.5, and some will still flash codes with the paperclip. These are a bit harder to scan as theyre not standardized. The easiest way is to use something like tunerpro-rt and a homemade serial cable to scan the computer.
Old Dec 12, 2010 | 01:20 AM
That's what I figured, the OP's car having only a few wires, you figure that it maybe a 4 bbl 305?
The OP doesn't say, but 4 bbl 305 with about three wires could be terminal a/b and one for the all computer controlled solenoids???
Old Dec 14, 2010 | 12:46 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Certainly a possiblity that its an early model as well. In that situation, the computer will be of minimal help if its a CC carb.
RenoLB8
Mar 25, 2025 04:10 PM
Fox118
Sep 1, 2015 04:07 PM
un4givin89
Dec 2, 2001 07:43 AM
NufNuffZ28
Nov 1, 2001 02:37 PM
Black Beauty
Dec 2, 2000 09:19 AM
