Speedometer is twice as fast as it should be
Old Dec 19, 2010 | 06:57 PM
grad's Avatar
I bypassed the old junk cruise control(didnt even have the stalk for it or wiring before I got it) and finally put in a new speedo cable. Well it works but the speedo is reading about double the right speed. It says I am doing 80 in third gear(which is impossible). I dont really know where to start on fixing this and the search didnt find anything but a speedos 10 miles off. I have an 83 firebird, 5 speed trans.
Old Dec 19, 2010 | 08:31 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer is twice as fast as it should be
Originally Posted by grad
I dont really know where to start on fixing this....
Welcome to TGO. Start with the following link:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Dec 19, 2010 | 09:57 PM
grad's Avatar
I already tried that link. I went through a few pages of searches and a bunch of different search terms but didnt find anything like what I have. Could the speedo be bad? I have 15 inch tires on it(someone swapped the doors,seats, and wheels from a camaro) but I doubt that would cause the speedo to be off by that much. Oh well, I guess at some point the trans was swapped and the speedo gear is wrong, its about all I can figure happened(probably swapped for one out of the camaro).
Old Dec 20, 2010 | 06:40 AM
JamesC's Avatar
You probably need to drop the diff cover and verify what the gear ratio is, then take a peek at the drive/driven gears in the trans to establish that they're correct for that rear.
https://www.thirdgen.org/forums/tran...-10-bolts.html
If all that's as it should be, the conclusion, since you have a new cable, is that the speedo head is malfunctioning.
JamesC
Old Dec 31, 2010 | 06:30 PM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
When you say speedo head, is it the speedometer itself that you look at in the cluster?
Old Dec 31, 2010 | 08:16 PM
JamesC's Avatar
Yes.
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
