help me ID these sbc iron heads with 2.02/1.60 valves
Old Dec 22, 2010 | 09:31 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
I picked up these heads yesterday from a guy on CL he said they are dart iron 200cc heads 64cc but i cant find any info or real casting numbers. They have 2.02/1.60 valves, perimeter and center bolt hols for valve covers, angle plug, and comparing the intake runners to a LT1 gasket i had laying around the are the same size. i took tons of pictures so hopefully someone will identify these.
Old Dec 22, 2010 | 09:32 AM
Re: help me ID these sbc iron heads with 2.02/1.60 valves
Old Dec 22, 2010 | 09:33 AM
Old Dec 22, 2010 | 05:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/post...371-post2.html
Old Dec 22, 2010 | 06:30 PM
Twin_Turbo's Avatar
those are world products heads, sportsman IIs. Specs still on WC website:
Casting ID Number: I-037
Material: High density cast iron
Valve Seats: Intake (integral), exhaust (hardened)
Valve Guides: Integral cast iron
Spring Seats: Machined for 1.560" and 1.250"
Valves: Manley stainless steel valves in assemblies (inconel exhaust valves on marine applications)
Valve Diameter: 2.020"" intake, 1.600" exhaust (11/32" stem)
Guide Plates: Stock
Rocker Arm Studs: Screw-in style
Rocker Arms: 1.5 ratio (use of 1.6 ratio will require elongation of pushrod holes)
Intake Runner: 200cc, standard port location
Exhaust Ports: 69cc, standard location
Combustion Chamber: 64cc or 72cc, straight or angled plug orientation
Spark Plug: 14mm 5/8" .460" reach tapered style
Valve Job: Multi-angle intake and radiused exhaust
Valve Cover Rail: Raised w/ perimeter and center bolt pattern
Valve Angle: Stock 23°
Accessory Bolt Holes: Stock
50-State Emissions legal
Accepted by most oval tracks and sanctions as stock replacements. Check with rule book
Old Dec 22, 2010 | 07:26 PM
that is awsome thanks for all the info. Im sure these heads will be fine with some port and polishing on a 383 with some boost. i dont see any problems with these heads for $350
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1985chevydude
Aug 20, 2015 12:29 AM
